12v circuit usually draws from .3A-.7Amp but i am not drawing any current
Discussion in 'The Projects Forum' started by WestTron, Oct 21, 2015.
  1. WestTron
    Oct 21, 2015
    Hello, i have an ecu (electronic control unit) that i am repairing and was wondering if i could get some advice/key points to reason it is not drawing any current. The unit is recieving 12v as it should, my 5v, 8v, and 100v are all good. Any takes?
    Thanks,
    -West
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    your current meter is bad
  3. GS3
    Sep 21, 2007
    408
    35
    Dead parrot? Joined the choir invisible?
  4. WestTron
    Oct 21, 2015
    My fault! it is a double decker board, having only to work on one side i forgot about the other side which i disconnected. reconnected and is working properly.
    Thanks though!
