12V car battery charger circuit
Discussion in 'The Projects Forum' started by riduan, Aug 17, 2009.
Thread Status:
Not open for further replies.
  1. riduan
    Aug 17, 2009
    6
    http://www.elecfree.com/circuit/battery-charger/12v-car-battery-charger/
    On reference to the link above, my group and i were to patch up the circuit and then test the charger. We did it without the transformer and the bridge rectifier. We directly connect the input to a 17Vdc power supply. But it did not work properly. The circuit can charge the 12V battery but it did not cut off once it is fully charged. The red led did not flicker as the battery is charging and did not light up once it is fully charged. We set the trimmer to null value at first, we follow the steps as we go along but still did not work properly. We try troubleshooting over and over but still could not find a solution. Can anyone help us with this? Do we need to modify the circuit? Do we need to change some of the components used? Would really appreciate the help.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    How did you know what component values to use in the circuit? I could not find a parts list at the link you provided.
    hgmjr
  3. riduan
    Aug 17, 2009
    6
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    While this thread has the working link, the other one has the more useful reply.
    This one is going to be closed as a duplicate post.
Thread Status:
