12v Battery Charger Circuit with Auto Cut off
Discussion in 'General Electronics Chat' started by green90, Oct 10, 2015.
  1. green90
    Sep 3, 2015
    23
    i saw this cct in circuit gallery and i have some question about it
    1-what will be the voltage on( cv or pin 5)coz it internally connect to voltage divider
    2-i think red led always on ..then what is purpose of it ?
    http://www.circuitsgallery.com/2013/04/automatic-battery-charger-controller.html
    Working
    • Positive terminal of the upper comparator of 555 is connected with reference voltage in order to turn OFF the charger if the battery charges above 13.8V.
    • why they said Positive terminal ?????? i think ( cv or pin 5) is negative terminal
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is another stupid circuit concocted by a newbie. The use of a 555 as a Schmitt-Trigger is not novel.
    How long do you think it will take to recharge a standard 65Ah automotive battery by passing the current through a 5Ω resistor? It's maximum current delivery will be about 200mA.
    green90 likes this.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Definitely one of the poorer ones I've seen...
    200mA isn't even sufficient for trickle charging; let alone charging hard enough and long enough to minimize sulfation.
    green90 likes this.
  4. samy555
    May 24, 2010
    116
    1- V at pin 5 = zener voltage = 5.1V
    2- It is here to indicate that the charger is on, i.e connected to the power and not related to batt state
    green90 likes this.
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    ...if it survives having a 555 supply voltage greater than the rated absolute maximum.
    green90 likes this.
