Hi All,
I'm new to the Forum as its quite a few years since I built electronic projects.
I have a small project I'm working on at home and I would be grateful for some assistance.
I'm fitting a 12v Tracking device to a horse box trailer, and I need to include a long life back up battery for the Tracking unit. The tracking device itself runs off 12v and it does not have an internal battery. My plan is to enclose the tracker and a 12v 1.2AH Lead Acid Rechargeable battery in a Waterproof poly-box. I will then connect the circuit to the trailers rear lights (12v). Therefore when the vehicles lights are on, it will recharge the battery and power the Tracker unit also. When the lights are switched off, the Lead Acid battery does the work. The Tracking device will switch to "sleep" mode when it scenes movement has stopped. In "Sleep" mode it consumes only 2mA. When in Track mode it consumes 150mA.
I must also ensure that the backup battery does not try to power the trailers electrical system also.
I'm sure this type of circuit is very common, but its years since I buit circuits and I'm a little out of date.
All help appreciated.
Barry
Barry
