12v ac to 12vdc with bridge rectifier and capacitor
Discussion in 'General Electronics Chat' started by collyd21, Jul 27, 2012.
  1. collyd21
    Jul 2, 2012
    14
    I HAVE MY CIRCUIT WIRED UP AS SUCH IN THE PICTURE, WHEN I TURN IT ON I GET 12VDC ACROSS THE CAPACITOR WITH NO LOAD CONNECT. BUT WHEN I CONNECT THE LOAD IT DROPS TO 9VDC, CAN SOMEBODY PLEASE TELL ME WHY THIS IR AND WHAT NEEDS TO BE DONE TO RECTIFY THE CIRCUIT TO GIVE 12VDC ACROSS THE LOAD?
    Thameem7 and Phyo Win like this.
  2. mkbutan
    Sep 30, 2008
    270
    16
    what's the input voltage?
    and what's the load on the Ckt.?
    which diodes are u using?
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    A 42 μF capacitor is a very low value for a buffer capacitor.
    You will need about 1500 μF for each ampere.
    Bertus
    PackratKing and mkbutan like this.
  4. collyd21
    Jul 2, 2012
    14
    hi yes i was thinkin the problem was the the size of the capacitor alright, thanks for your help
  5. #12
    Nov 30, 2010
    16,665
    7,310
    If you really have 12 VAC, this should charge the capacitor to about 15.5 or 16 volts. You need to get picky about your measurements so they wil lead you to the error.
  6. collyd21
    Jul 2, 2012
    14
    i put in a 1000uF capacitor and getting 11 volts across the load, but when i put in a 2200uF cap the voltage across the load begins to jump randomly up and down from 2v up to 6v down to 4v up to 7v??
  7. mkbutan
    Sep 30, 2008
    270
    16
    1000μf is good but it should be min. 25v(1000μF/25v)
    just make sour that the capacitor voltage should be twice of the operating I/P voltage(secondary from transformer and after the rectifier diodes)
  8. gerty
    Aug 30, 2007
    1,154
    304
    mkbutan likes this.
  9. mkbutan
    Sep 30, 2008
    270
    16
    Thanks for the link http://www.hammondmfg.com/pdf/5c007.pdf
    but whats the difference between these two
    FULLWAVE BRIDGE Choke Input Load
    FULLWAVE BRIDGE Capacitor Input Load
    or whats the use of inductor (COIL/CHOKE)?
    pl explane
  10. zubair306
    Dec 21, 2013
    i have 4 lights installed with 12vdc battery.when i turn on the lights ,the get blink.i think voltage drop.can anybody suggent me what will the capacitor rating to use for it.?
  11. gootee
    Apr 24, 2007
    447
    50
    What is the rating of the input source? It seems to not be able to supply enough current. There should be be at least 15v with no load, if the input is 12v RMS. 12v RMS should give 17v peaks. Maybe you need a heavier transformer. Or maybe your input is only 13.5 to 14 volts peak?
    Anyway, once you have the correct transformer, you can calculate the capacitance needed:
    Since i = C dv/dt we can make some assumption and get close-enough with C = i dt/dv where i is the maximum load current, dt is the time between charging pulses which is 1/2fmains, and dv is the voltage dip you want to allow, or the amplitude of the ripple voltage.
  12. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Zubair306, you're hijacking the thread. Start your own, describing your circuit and light ratings clearly.
  13. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    The Capacitor choke filter was used for many years an amplifiers and radio recievers.
    Often seen with a cap - choke - cap, it is known as a Pi filter because of the obvious configuration.
    The capacitor stores energy, the choke has the effect of high impedance at the ripple frequency allowing DC to pass un-reduced, therefore filtering or removing the AC ripple .
    Max.
  14. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I see it's a 18mo old thread!
    Max.
