Hay,
I want to connect 12v 80watt fan direct to 18v 60watt panel is it ok or it will burn the fan.
No it isn't good. You have 18 volts 60 Watts which is 18 Volts at 3.333 Amps. You have 60 watts total power and that is as good as it gets.It will not work with it max power for 60W that I'm sure but if I had 12v regulator in between is it good.
by Jake Hertz
by Aaron Carman
