I need to make a variable timer circuit using a 555 timer that I can control to be on for 1-5 minutes. I have posted a picture of where I am so far but the problem is that the 12v motor stays on until the power is stopped. The potentiometer doesn't seem to do much. I'm not sure what the problem is?
Also is it OK to run the motor and circuit from the same power supply or should I use a relay between them?
Help is much appreciated, cheers.
