So of course I am always setting my goals high and this is no exception. I am looking to put together a 12v 300-350 amp pwm motor control. I am planning on using a pic for the operator interactions, (pwm parameters, 8-seg displays, start/stop, backup relay disconnect) which i have under control. My problems begin with the pwm driving circuit and paralleling the mosfets to reach these power levels. The drive only needs to be unidirectional with a duty cycle around probabaly 1-3 min on 30+ min off. I have seen multiple designs use dedicated Mosfet Driver ICs but I wasn't sure if this was the way to go. What is the benifit of using a driver chip over over driving a transistor from the the 12v rail and the mosfet gates. Any suggestions or input is welcome,
