Hi, I'm experimenting with a project to send a stored ir command when a switch or sensor is tripped.
I've found various code examples online showing the timing aspect of the 38khz carrier and sending the input from a pc.
I'm stuck in how to program in EEPROM an ir code so it isn't lost on power down.
I'm using a Microchip PICkit 1, so I'm somewhat restricted to the 12F675.
Any help anyone can provide, or a site with better code samples then those I've found, would be appreciated.
Thanks,
Thanks,
