12F635 & FAN REGULATOR - Help needed to understand
Discussion in 'The Projects Forum' started by rfsingh81, Aug 24, 2009.
  1. rfsingh81
    May 13, 2009
    Hello
    I have 12F635 with me, with this little baby I want to be able to control the speed of my fan. Plan is to control it remotely usinig my RF Modules in the second stage. I will try to keep you all updated on this project as it will be a start from scratch. I will be using picbasic pro for this.
    I want to add that for this project I have available MOC 3031/32/33 optocouplers + Triac, I dont know about zero crossing (so any help with the code+brief description will be helpful) and it will be used in my home with 240V 50Hz.
    Any help or pointing in the right direction will be much appreciated
  2. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    If you are intersted, there is a post with a (PIC16f, I think) 2 pages back in this forum using IR remote. You could easily modify it as he has also provided the source code there. Take a look, he uses a triac also.
