12F1822 programming problem
Discussion in 'Embedded Systems and Microcontrollers' started by MaxHeadRoom, Oct 11, 2016.
  1. MaxHeadRoom
    Thread Starter Expert
    Jul 18, 2013
    10,837
    2,511
    Put together a program board for a 12f1822 and when try to DL a prog get the following:
    Running self test...
    Self test completed
    Firmware Suite Version...... 01.28.90
    Firmware type......................Enhanced Midrange
    PICkit 3 Connected.
    Target Detected
    Target Device ID (00000000) does not match expected Device
    ID (00002700).
    Programming...
    The following memory regions failed to program correctly:
    Program Memory
    Address: 00000000 Expected Value: 00000021 Received Value: 00000000
    Programming failed
    Any clues as to the cause, or what to correct it?
    All connections appear correct. It seems target detected but ID?
    Max.
  2. AlbertHall
    Jun 4, 2014
    2,262
    448
    Target ID 00000.... generally means PK3 can't communicate with the PIC.
    ICSPDAT and ICSPCLK right way round?
    Other components on MCLR, ICSPDAT, ICSPCLK interfering?
  3. MaxHeadRoom
    Jul 18, 2013
    10,837
    2,511
    Thanks, Got it, the old wire whisker across an adjacent strip (strip board) VPP.
    Max.
  4. dannyf
    Sep 13, 2015
    2,196
    417
    Those are mostly due to wiring or dead chip.
