MaxHeadRoom
- Joined Jul 18, 2013
- 28,696
In the link you provided for the Pickit-2 update, ensure the device list is download first, (Zip file) and placed in the Pickit-2.exe directory.
Max.
Max.
I opened the device list file in notepad and found the PIC12F1822; is that what you meant by "do a find?"Do a find for "PIC12F1822"...it's there...
I even opened up the device list file to be sure...
I meant searching on the page I linked, but searching the device list for it works too!(good thing the names are in ASCII)I opened the device list file in notepad and found the PIC12F1822; is that what you meant by "do a find?"
That's what I think I am doing. I downloaded the latest dat file from the Microchip web site, looked at it in Notepad, found the 12F1822, and copied the file over the old file in the PICkit2 folder. But still the standalone app doesn't "see" the 12F1822. I don't know what I am doing wrong.Use the stand-alone programming application and the most recent version of its DAT file...
I'm using the PICkit2 stand-alone tool with 12F1822 and other enhanced midrange parts with the following versions.My 12F1822 chips arrived today, but my PICkit2 software says, "No Device Detected." Suggestions?
MUCH nicer than Gremlins........And personally, I've never given up the belief that fairys exist,
Geoff,Hi all,
Hope this isn't considered to be hijacking! I've been looking at the data sheets for these pics and had a couple questions?
Are the int osc accurate enough for serial communication? I've used 18f2523's for serial before and used a crystal as I think I was told the int osc wasn't accurate enough?
Can I use the spi and I2C modules on the same pic? I think the pull ups for the I2C might bother the spi bus?
Cheers Geoff
I will second what Tracecom has said; when asking a question , start a new thread.Hi all,
Cheers Geoff
Yep. Compilers load all the DAT or INF files (for the different PICs) when the compiler starts up....
As I think it through, perhaps restarting my computer after downloading and installing the new dat file is the real fix?
