123PICMCUExperimentsfortheEvilGenius-Help
Discussion in 'General Electronics Chat' started by mpuvdd, Dec 25, 2007.
  1. mpuvdd
    Thread Starter Active Member
    Feb 11, 2007
    50
    If anyone has this book, could you please help me with experiment 47; Producing Random #'s. Have you gotten this thing to work? Is the code even valid, or what? I've set this up many times, and yet it still fails to work. I know how to use LCD's, but maybe this is just another of Myke's (the author) typos.
    Thanks for your consideration,
    mpuvdd
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Copy your code and paste it here so people can compare it to their copy in the book.
  3. mpuvdd
    Feb 11, 2007
    50
    I got this code from http://pic18fusb.online.fr/PicKit2, only because it is not shown in the book.
    #include <pic.h>
    /* cRandom.c - Display a Random Number Each Time a Button is Pressed
    This Program Initializes Hitachi 44780 Based LCD in 4 Bit Mode
    and then writes a simple string to it. The simulator was used
    to time delay values.
    LCD Write Information can be found at http://www.myke.com
    RA5 - Button Input
    RC3:RC0 - LCD I/O D7:D4 (Pins 14:11)
    RC4 - LCD E Clocking Pin
    RC5 - LCD R/S Pin
    myke predko
    04.11.08
    __CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT \
    & UNPROTECT & BORDIS & IESODIS & FCMDIS);
    // 1234567890123456
    const char TopMessage[] = " Random Number: ";
    const char BotMessage[] = " "; // Number Follows
    #define Button RA5 // Define Button Input
    #define E RC4 // Define the LCD Control Pins
    #define RS RC5
    const int Twentyms = 1250; // Declare a Constant for 20 ms Delay
    const int Fivems = 300;
    const int TwoHundredus = 10;
    LCDWrite(int LCDData, int RSValue)
    int i, j;
    PORTC = (LCDData >> 4) & 0x0F; // Get High 4 Bits for Output
    RS = RSValue;
    E = 1; E = 0; // Toggle the High 4 Bits Out
    PORTC = LCDData & 0x0F; // Get Low 4 Bits for Output
    RS = RSValue;
    E = 1; E = 0; // Toggle the Low 4 Bits Out
    if ((0 == (LCDData & 0xFC)) && (0 == RSValue))
    j = Fivems; // Set Delay Interval
    else
    j = TwoHundredus;
    for (i = 0; i < j; i++); // Delay for Character
    } // End LCDWrite
    main()
    int i, j;
    PORTC = 0; // Start with Everything Low
    CMCON0 = 7; // Turn off Comparators
    ANSEL = 0; // Turn off ADC
    TRISC = 0; // All of PORTC are Outputs
    OPTION = 0b01001111; // Run TMR0 From PIC MCU Clock
    // Initialize LCD according to the Web Page
    j = Twentyms;
    for (i = 0; i < j; i++); // Wait for LCD to Power Up
    PORTC = 3; // Start Initialization Process
    E = 1; E = 0; // Send Reset Command
    j = Fivems;
    E = 1; E = 0; // Repeat Reset Command
    j = TwoHundredus;
    E = 1; E = 0; // Repeat Reset Command Third Time
    j = TwoHundredus;
    PORTC = 2; // Initialize LCD 4 Bit Mode
    E = 1; E = 0;
    j = TwoHundredus;
    LCDWrite(0b00101000, 0); // LCD is 4 Bit I/F, 2 Line
    LCDWrite(0b00000001, 0); // Clear LCD
    LCDWrite(0b00000110, 0); // Move Cursor After Each Character
    LCDWrite(0b00001110, 0); // Turn On LCD and Enable Cursor
    for (i = 0; TopMessage != 0; i++)
    LCDWrite(TopMessage, 1);
    while(1 == 1) // Loop Around Waiting for Button
    i = 0; // Wait 20 ms for Button Up
    while (i < Twentyms)
    if (0 == Button) // Button Down/Start over
    i = 0;
    else // Button Up/Increment Count
    i = i + 1;
    NOP();
    i = 0; // Wait 20 ms for Button Down
    if (1 == Button) // Button Up/Start over
    i = 0;
    else // Button Down/Increment Count
    i = i + 1;
    LCDWrite(0b11000000, 0);// Move Cursor to the Second Line
    for (i = 0; BotMessage != 0; i++)
    LCDWrite(BotMessage, 1);
    i = TMR0; // Save TMR0 Value
    if (i > 100) // Convert TMR0 Value to Decimal
    LCDWrite((i / 100) + '0', 1);
    else // No Hundreds to Display
    LCDWrite(' ', 1);
    if (i > 10)
    i = i % 100; // Not Greater than 10
    LCDWrite((i / 10) + '0', 1);
    else
    LCDWrite(' ', 1);
    LCDWrite((i % 10) + '0', 1);
    } // elihw
    } // End cRandom
