I'm working on a project which will require a 5Vdc signal from a 120VAC outlet. I know you can throw in a transformer, rectifier, and some other goods and achieve this, but I need something fairly small.
The ac to usb plugs come to mind, but I haven't found much on what is inside them.
Any suggestions on small parts to use or what is in the ac to usb plugs?
Thanks!
Thanks!
