Hey guys,
I'm planning on building a TDA7294 circuit (http://www.st.com/stonline/books/pdf/docs/1057.pdf)
I've been playing around with smaller amps such as the tda2050 and tda2030 but so far I have just been using batteries to power them. I recently found an old wall unit that used a transformer, rectifiers, and a capacitor to drop the voltage from 120VAC to about 10VDC and I hooked this up to a TDA2030 and it works fine... But I'm kinda confused about the +40,-40, and ground required to run a TDA7294. Now if this were 12V I'm pretty sure I could get +,-, and ground using a split power supply? but how am I to get 40V. Also, does it matter if this voltage is AC or DC? And if I need to use a transformer, where do I get one that steps down 120 VAC to 40V. Basically what I'm asking is what is the best way to drop 120V to 40V?
Thanks!
Connor Smith
Thanks!
Connor Smith
