I am working on a school project of creating a LED bulb that works on standard 110-120 VAC. The bulb should serve as a viable replacement for a 60 incandescent bulb. The plan was to run the 120VAC through a 2:1 transformer, then through a rectifier so that the output would be around 60VDC(this will serve as the input to various components and the LED driver). I am having trouble finding a transformer that will meet the desired space requirements (very compact) and still meet the voltage and current requirements (60VDC & around 1.5-2 amps). I suppose i could just place a large resistor in line before the rectifier, but this seems to be very wasteful. Can you help me find another method to step down the voltage efficiently.
Thanks in advance
Thanks in advance
