120VAC - 130VDC
Discussion in 'General Electronics Chat' started by Khalid Abur-Rahman, Apr 10, 2009.
  1. Khalid Abur-Rahman
    Thread Starter Active Member
    Dec 25, 2008
    34
    is this the right way to go about doing it?
    Get about 92 volts AC from a transformer.
    Connect this to a bridge rectifier to give you pulsing DC with peaks of about 130 volts. (92 times square root of 2 is 130 )
    Connect a large capacitor of 5000 uF rated at 200 volts or more across the output of the bridge rectifier.
    Take the output from across the 5000 uF capacitor. This will be close to 130 volts.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    More like 128.8, but close, yes.
  3. chyadesh
    Member
    Apr 10, 2009
    19
    hi'
    here is an answer for u....
    first of all we really don't need any transformer while working with bridge rectifier..... If to get output of ur requried the connect a load resistor across the rectifier../......;please reply to this suggestion/ instead of transformer u can use ac regulated power supply
