120 volt motor timer
Discussion in 'The Projects Forum' started by R.K. ONeil Jr, Mar 14, 2016.
  1. R.K. ONeil Jr
    Mar 14, 2016
    Howdy all,
    I am trying to wire an 120volt 20 amp electric motor to a timer and the timer will be 0-60 seconds ( when I find the right one ! panel mount hopefully) I need to be able to hit an momentary on switch and get the motor running for 0-60 seconds and have the motor turn off at the end of the preset time. and the timer reset for the next activation. I would like this to all be a 120 volt circuit. any and all help is greatly appreciated!
    R.K.
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Googling 'time delay relay' brings up lots of hits.
  3. TheButtonThief
    Feb 26, 2011
    219
    38
    20A? You'll either have to find a timed relay that's capable of switching 20A or any other timed relay and a contactor.
  4. R.K. ONeil Jr
    Mar 14, 2016
    Many thanks That is what I was thing but not sure!
  5. R.K. ONeil Jr
    Mar 14, 2016
    Many Thanks!
  6. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,514
    I assume this is a 1ph induction motor? If so that is fairly large for 1ph 120v (3HP).
    I would suggest that you use a Special Purpose contactor as these are meant for high cycle times, HVAC systems etc.
    Apart from that a timer and momentary P.B.
    Max.
