120 vac table lamp with photoresistor
Discussion in 'The Projects Forum' started by Segga17, Aug 3, 2015.
Thread Status:
Not open for further replies.
  1. Segga17
    Aug 3, 2015
    Hello, I'm trying to make my own table lamp. I'm using a 3.5 watt and 120 VAC LED bulb which is connected in series to a photoresistor, so the lamp lights when there's light reaching the photoresistor. I want to add a simple 3.5 V LED to the lamp to show when the lamp is plugged in. How can I connect this new LED to this simple circuit? Do I have to add a resistor and a diode? Are this photoresistors good for this project? Thank you for your help :)
  2. DickCappels
    Aug 21, 2008
    2,777
    674
    Welcome to allaboutcircuits.com.
    At this time, discussion of LEDs connected to the AC line without proper isolation, such as a transformer power supply, is not permitted on allaboutcircuits.com.
    The subject is discussed on the Elector-Tech site, http://www.electro-tech-online.com/
    In accordance with policy, this thread is locked to prevent further discussion.
Thread Status:
