120 V LED powered by 12 V DC
Discussion in 'The Projects Forum' started by bairnich, Mar 19, 2016.
  1. bairnich
    Mar 19, 2016
    Hopefully some electrical wizards can help me.
    I have a few LED lights I'd like to run off a 12 V car battery. I know minimal about converting DC to AC or visa versa. Do I just need a converter? to get me from my 12v DC to power my 120v AC lights?? The light info is below
    http://thediyoutlet.com/products/50w-led-waterproof-flood-light-fixture-cool-white
    Any info would be appreciated. The simpler the set-up the better.
  2. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Buy a car 12V-120V converter price between the 30-70$.
    Building it yourself is dangerous and when build not correct it will produce a lot of unwanted radio frequencies.
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Might be cheaper just to buy a 12V 50W light.
  4. blocco a spirale
    Jun 18, 2008
    1,460
    370
    If for some reason you can't use a 12V floodlight, buy an inverter; it's impossible to build one cheaper.
  5. Dodgydave
    Jun 22, 2012
    5,150
    769
    I would buy a 12V 50w light, even if you use an inverter its still going to pull at leat 4 to 5 amps from the car battery.
