Greetings
I have 5 (somewhat related) questions
1) Regarding the AC socket with the male pins that are on the back of most monitors and PCs which pin is the hot and which is the neutral?
2) I could plug an AC cord up to the socket and if I do this on a standard male plug that plugs into a wall outlet which of those 2 pins are the hot and neutral?
3) essentially the same question as 2) on an AC plug that plugs into the wall that has 1 pin that is slightly wider than the one beside it (that wont plug into the female side of Christmas lights J ) is the slightly wider pin the hot?
4) How do I call out the simple AC socket found in the back of monitors and pcs? I have searched digi-key and thus far the closest Ive found is a module with the socket but also with a switch and fuse for around 8 to 9 dollars. I would like the simple socket for cheap.
5) If switching something on 120 VAC household wiring light bulb for example would you switch the hot or the neutral? Im guessing the hot.
Sparky
Sparky
