Doesn't this support my readings then? I'm using 2 phases of a 3 phase system. Even if my 2 phases, A and B, are carrying equal current, the neutral will not carry 0 current because the C phase vector (which I'm not using) of 0 amps needs to be included in the calculation. This makes sense because A and B are 120° and not 180 out of phase.
I would say, yes.
Can't get a straight answer out of these guys. They seem to be back tracking.
I did the math and used an online calculator. Everything I find agrees with your readings.
Who are you gonna believe? Your lying eyes?
If I'm not convinced by tomorrow, I'll connect a couple 300 watt bulbs across 208. Then run a wire from the center tap to neutral and see for myself.
