I bought an oven that could be 3 phase but is hard wired from factory for 120/208/1. The spec sheet reads for this configuration L1 pulls 22 amps and L2 37 amps. A warning on the oven states not to energize the unit with more than 150 volts in any circuit to L1 or L3 (L3 is not used as wired) It has a cord with 4 legged 50 amp plug. A hand drawn diagram on the back of the oven, shows a nuetral (w) , ground (g) , black (x) and red (y) for the source receptical.
I have an outlet in my commercial space that I want to use for this oven. It has phase A & phase B (ungrounded) each sourced by a 8 AWG wire and one 10 awg Nuetral (grounded) as well as one 10 awg grounded wire.
I have a few questions:
I thought that in single phase 208V, current flowed back and forth between phase A & B. How can L1 (A) pull 22 amps and L2 (B) pull 37 amps? Does the neutral provide the path for the extra amps?
Do I need to gang two different breakers one 30 amp (for phase A "L1") & another 40 amp (for phase B "L2") in the power panel? If two breakers do their switches need to be tied together?
