Hello everyone, New member here. My name is Jerry. I have a project i found on a fishing website that i am in the process of making right now. I have always wanted to do some night fishing and had read a couple articles on how great the crappie fishing can be at night with an underwater light source. I ran across a thread that showed how to build a green fluorescent underwater light that runs off 12 volts. A commercial version of this is made and called the Green Monster. Costs about $185. A parts list and explanation showed how easy it could be built for about $60.
It is built from 3" PVC tubing. They used a fluorscent bulb cover for the tubing, but i went with schedule 40 clear PVC for added protection. It takes an industrial green F20T 12/G green fluoresent bulb, and an 18 watt 12 volt ballast. I have links below for the bulb and ballast.
My question is when i wire the bulb to the 12 volt ballast, what gauge wire should i be using? I don't want anymore resistance than i need.
Put a couple battery clamps on the end of the length of wire running from the ballast to the battery, seal it all up with %100 silicone and i should be in buisness. Is there a certain type or gauge wire i should be using to go from the battery to the ballast too, seeing that i'm only running 12 volts to the ballast?
http://store.solar-electric.com/tl-ib-151.html
http://atlantalightbulbs.com/ecart/nw012104/INDUSTRIALF20T12.GGREEN.htm
These are pictures from the thread i was reading. I'm in the middle of it right now but haven't done any wiring yet. I'm building two, just to be sure i have enough light.
Any other tip?
Any other tip?
