12 VOLT POWER SUPPLY
Discussion in 'General Electronics Chat' started by David Bradley, Oct 11, 2015.
  1. David Bradley
    Oct 11, 2015
    Hi
    I have an FCB 1010 with a very noisy internal power supply. I have spliced into the wires coming out of the power supply with a socket. I pick up 10.5volts from my socket when the noisy internal power supply is used.
    Can I now just unplug the fcb from the mains (uk ). then plug in a nice quiet 10.5 volt external power supply ?
    What external power supply to use ?
    Regards to all db.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    The FCB1010 requires a 10V AC (not DC) supply if you intend to bypass its internal supply.
    some info here..http://www.naslada.net/knowhow/fcb1010/FCB1010 Phantom Power Adaptor.pdf
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from 12 VOLT POWER SUPPLY
    David Bradley likes this.
  4. David Bradley
    Oct 11, 2015
  5. David Bradley
    Oct 11, 2015
    Thank you My Bad sorry. ;-)
  6. David Bradley
    Oct 11, 2015
    Ref " The FCB1010 requires a 10V AC (not DC) supply if you intend to bypass its internal supply."
    I am in the uk which one to use ? Is my quest !
