12 volt inverter
Discussion in 'General Electronics Chat' started by thangavelsm3246, Apr 28, 2010.
  1. thangavelsm3246
    Apr 28, 2010
    i need circuit diagram 12 DC to a 220 AC converter and watts range is 1000watts. pls help me.... this is my mail id: <snip>
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is not a really practical project, especially starting from scratch. For instance, that 1000 watt output will take a 12 volt battery that can supply over 84 amps of current. Any losses will increase that current. That means multiple batteries and very heavy conductors.
    kingdano likes this.
  3. VoodooMojo
    Nov 28, 2009
    503
    53
    a few years ago I found this one on the internet.
    google search "1000 watt inverter circuit". Thats how I found it.
    I remember having to tweek a few things but exactly what escapes me at the moment. I am on a mission now so time is tight.
    I needed it to power a small mig welder (240 volt) at a remote location.
    It worked well.
    I am away from the shop until the weekend so I don't have access to the reworked drawings or component values and numbers for my 240 volt til then.
    Beenthere says it like it is.
    I ran mine off a V8 engine with a 125 amp alternator and a secondary battery. Otherwise you will need a DC forklift sized battery for any worthwhile run time.
    Edit:
    I used a voltage converter/stabalizer for the voltage bump up.
    I had most all the components so the cost to me was nil but it may end up being a costly endeavor from scratch.
    !DSeva likes this.
  4. !DSeva
    Jun 27, 2007
    very nice, thanks
  5. R!f@@
    Apr 2, 2009
    8,789
    771
    hey mojo
    I like to discuss about that inverter but not here.
