12 volt dc to 12 volt ac
Discussion in 'General Electronics Chat' started by Lightfire, May 9, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I am asking if it possible to happened or made then. Is it possible?
    My plan is to make an AC power source. :) 240 volts AC (mains) is very very lethal.:eek:
    So, I guess, I only need 12 volt AC. :)
    My problem is maybe some of my or totally whole of my 12 volt lightning devices. Maybe because they are only workable with DC.:(
    So guys, how do I made 12 volt AC power source. I heard of an inverter.
    pls help~~~
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
  3. gerty
    Aug 30, 2007
    1,154
    304
    If you are sure you want ac it sounds like all you need is a step down transformer, wall wart type would be best. They also make them that have a dc output,which is more common.
    edit: beat me by a few seconds
  4. Lightfire
    Oct 5, 2010
    690
    21
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    Why do you want AC?
  6. tom66
    May 9, 2009
    2,613
    214
    You could use an oscillator at the required frequency feeding an ac coupling capacitor. However, this would only net you 12 / 2sqrt(2) volts ac or about 4.26V. You would need a higher voltage to produce the minimum required 12 * 2sqrt(2) swing, or 34V, assuming your virtual ac neutral is at 17V.
  7. Lightfire
    Oct 5, 2010
    690
    21
    Because I want to have an AC power source. :)
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
    Then just get a step down transformer as already suggested...
    But if this is still for your DC lightbulb project it seems silly to step down to 12VAC then rectify it externally instead of just using a suitable 12VDC power supply
  9. ErnieM
    Apr 24, 2011
    7,438
    1,626
    Ikea may have the thing you want, look in their lighting department. They have several lines of 12V lights and some hefty transformers to support them.
    And they be inexpensive if you have one locally.
  10. nbw
    Member
    May 8, 2011
    36
    10
    I second the Ikea lighting idea. Those little transformers are usually good for a few amps.
  11. Kermit2
    Feb 5, 2010
    3,852
    967
    He's is living in the Phillipines gentlemen. Not exactly a place with a Starbucks on every corner...
    The transformer idea is still a good one however. The chances are good that you could find a 'junked' piece of electronics that would have a useable transformer inside which you could reclaim and use for other purposes.
