12 volt dc power supply
Discussion in 'The Projects Forum' started by dane, Jan 31, 2009.
  1. dane
    Jan 31, 2009
    am building a 12 volt dc power supply with the following specifications:
    output power- 1 watt
    output voltage- 12volt
    output current- 1amp
    ripple factor- <1%
    i need the formulas to calculate capacitance, diode, transformers and other components. i didnt get any values for the components thats why i need the formulas. plz help
    thank you!
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Your caculation for the power is wrong.
    A 12 Volts power supply that can deliver 1 A has a power of 12 Volts X 1 Ampere = 12 Watts.
    Here is a simple power supply schematic from bill bowdens webpage with a LM 317.
    It is capable of 1.5 Ampere.
    http://ourworld.compuserve.com/homepages/Bill_Bowden/page12.htm
    Greetings,
    Bertus
  3. dane
    Jan 31, 2009
    that site is no help. sorry about that yes it it is 12 watts
  4. mik3
    Feb 4, 2008
    4,846
    63
    Is this a school assignment or a personal project?
    If it is a personal project you can use a LM7812 to regulate the output voltage.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. dane
    Jan 31, 2009
    yes it is a school assignment
  7. mik3
    Feb 4, 2008
    4,846
    63
    These equations were derived by assuming the ripple voltage as a triangular wave and give approximations of the actual values.
    Vr=Idc/(2*f*C)
    Vr=ripple voltage peak-peak
    Idc=DC current through the load
    f=supply frequency
    C=filter capacitance
    k=Vrms/Vdc
    k=ripple factor
    Vrms=Vr/(2*sqrt3) rms ripple voltage
    Vdc=DC voltage across the load
    Vdc=1/{1+1/[4*f*C*R]}
    f=supply frequency
    R=load resistance
