12 v DC Load tester
Discussion in 'General Electronics Chat' started by ahitechs, Sep 30, 2010.
  1. ahitechs
    Sep 30, 2010
    we want to test the load of 12 v DC supply , up to what maximum current limit it can deliver to load , any good load tester can you suggest ?
  2. retched
    Dec 5, 2009
    5,201
    313
    What range do you need? 0 to 1 amp? 0 to 10 amp? 1000 amp?
  3. ahitechs
    Sep 30, 2010
    tanks fot the reply , we need atleast 10 -20 amp load test
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    There is a piece of test equipment called an Electronic Load, basically it is a programmable constant current source with lots of fans.
    You could always get lots of resistors, around 10-15W resistors X20 should do it.
    Or you could make a quick and dirty electronic load with a bank of transitors on a heat sink.
  5. ahitechs
    Sep 30, 2010
    Thanks Bill
    Will you please help me to design that circuit, I need some more detail .
    Hope for your support.
  6. retched
    Dec 5, 2009
    5,201
    313
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    This weekend Harbor Freight has a 12V battery load tester on sale for something like $12.99. I haven't looked at it but if it's like most normal battery testers it will have a simple ammeter movement included, although the scale may only be good/?/bad but easy enough to interpret.
    Yup, here it is and it won't be much higher than $12.99 if you can't make it over there by tomorrow.
    http://www.harborfreight.com/100-am...=finalday&utm_medium=email&utm_campaign=3910B
    You want item #90636
