I am trying to wire a bus door to open and close using 4 relays. Two for a momentary power source open/ close ( latching ) and two for switch reversing of the 12 v motor.
The bus also has 2 micro switches on at each end of the doors open / close locations. they are open when at the full extent ( open / close )
I have sat down with a pad to determine wiring and have no good ideas as to how to terminate the latching relay at the end of the run.
The switch on the dash gives a momentary power, I can get the latching system to supply the switch reversing relays, then stop by diconecting the latch relay's ground. Just not sure how to go the other way.
Using 5 prong 30 amp relay's
Any help appreciated.
Alan
Alan
