Hi guys..
with USB devices - say for example my HTC One X or the Samsung Galaxy S2 etc.. they just look for a micro USB to charge from etc..
what's I'd like to understand it - the smarts, for charging the battery inside - are they done by the phone, or by the USB charger external.. ie if I could just hookup my simple old 0-30Vdc up to 5Amp bench power supply.. set it to 5Volts (accurately) and then connect that to the right pins on the USB cable.. is that at good as anything ..? ie from the perspective of the phone, looking back at the power supply - is it just looking for a dumb 5Vdc (clean, no ripple etc) ..??
this then I guess leads on to the greater question - why can't I just take a 12V input, put it accross a 7805 (to-220 package) and then put the output into my phone.. what is wrong with that etc..?
I have a 12V charger.. which just gives you a USB output - there is quite a bit of circuitry in there.. just wondering what else it would do on top of the 7805 etc..?
I hope my question is not too confusing.. just trying to get my head around it a little.
Thanks!
Thanks!
