12 Pulse Rectifier
Discussion in 'General Electronics Chat' started by PAB, Jul 1, 2007.
  1. PAB
    Jun 21, 2007
    6
    gentlemen, please read and reply.......
    I have a 6 phase 380VRMS @50Hz supplied SCR rectifier, I need to know what is the voltage on the DC Bus between + and -.
    I understand there is a simple formula to calculate this. Am I correct?
    (Supply info: 3 phase PRI (415VRMS) supplied transformer @ 50Hz, and SEC output of 380VRMS on a DELTA Tap, and 380RMS on a STAR Tap.
    gives 2 sets of 3 phases with a phase difference of 30degrees (if you impose the star winding over the delta). Once (SCR) rectified there will be 12 pulses).
    I have posted this question before and no-one replied.
    Please help.:confused:
  2. wireaddict
    Nov 1, 2006
    133
    The info I have for a 6-phase, full-wave rectifier circuit, assuming 180 degree SCR firing angle is 2.336 times your RMS phase-to-phase voltage or about 887VDC, although, to me, this seems high. This same book shows that, for a six-phase, half-wave rectifier circuit you multiply the phase-to-phase RMS voltage by a more reasonable 1.35 to get your DC output voltage. Hope this helps.
  3. PAB
    Jun 21, 2007
    6
    Dave, This 2.336 formula does not seem correct, as I have been informed that there is over 1100V DC present on the bus. It sounds about right for a 3 phase rectifier though as it would have 6 pulses present on the DC Bus.
    On the 6 phase rectifier DC bus there would be 12 pulses over the space of 50Hz (every 20milli seconds).
    Any other suggestions?
