12/military clock
Discussion in 'The Projects Forum' started by krogerson2, Jan 27, 2009.
  1. krogerson2
    Jan 8, 2009
    24
    I am designing a digital clock that switches between military and 12hr time and am not sure what chip to use for the DIV 10 and DIV 6 Portions of the circuit. Also i will be using a common seconds and minutes circuit but i will need a 2 to 1 mux and am not sure what chip that would be either
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You need to start by deciding which logic family you are going to use. Any decade counter (BCD) can divide by 10. You will need an external gate to reset a counter at a count of 6.
    Not at all sure what you mean by -
    - can you expand on that?
    Do you have any schematics you can post up?
  3. krogerson2
    Jan 8, 2009
    24
    well the minutes and seconds can be used by both the military portion and the 12hr portion but then it would have to go into a seperated 24 hour and 12hr for the "hours" counter then in to a 2 to 1 mux to switch between the two what would be a reccomended decade counter would a 74293 work for that?
  4. krogerson2
    Jan 8, 2009
    24
    wont i need a enable line on the chips in order for them to switch to the next number after the one before it cycles through its process of the EG: 0-9 on the seconds then the other seconds display will turn to 1 and so on
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
  6. krogerson2
    Jan 8, 2009
    24
    I have been looking at the 7490 chip to use that but i don't know how to connect the chips together because don't i need a enable line to not get the next stage to count until the first stage gets to 9 for example on the seconds
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do you have any experience working with logic, and do you have a solderless breadboard to construct circuits on?
  8. krogerson2
    Jan 8, 2009
    24
    unfortunatley i am drawing a blank on how that works and i do have a solderless bread board i cant remember how it knows that they are not cascaded to count to like 8 bits or is that what i want just split the display into two different parts
