12 Hour Digital Clock AM/PM LED Indicator
Discussion in 'Homework Help' started by nephelem, Mar 27, 2016.
  1. nephelem
    Jan 24, 2016
    22
    I have built this schematic 12 hour digital clock .jpg and now it's working. How can I add 2 LEDs to indicate AM/PM since this is a 12-hour digital clock? Please help me :(
  2. DickCappels
    Aug 21, 2008
    2,777
    674
    This is only an idea but you could makeba circuit that puts out a pulse when the two digits in the hours part of the circuit changes to "12" and use that toggle a flip-flop that drives the AM/PM LED.
  3. crutschow
    Mar 14, 2008
    13,505
    3,379
    Unless it's an alarm clock, why do you want an AM/PM indication?
  4. nephelem
    Jan 24, 2016
    22
    Yep, that's exactly what's on my mind but I don't know how to build a circuit for that. Tried to search on google but there's no exact or simply closer idea for that circuit.
  5. nephelem
    Jan 24, 2016
    22
    Our professor told us to build a 12 hour clock with 2 LEDs for AM/PM indication. We will actually connect some pins on circuit to the corresponding GPIO pins on Altera DE1 Board (Quartus - Cyclone II Device) and program the logic gates used to make it run as how it should be.
  6. DickCappels
    Aug 21, 2008
    2,777
    674
    It should not be difficult logic to come up with. Do you know what the BCD patterns corresponding to 1 and 2? It should be an easy circuit, the "2" is only displayed in the hours digit two times. A binary-to-decimal decoder and some AND gates driving a flip-flop could do it.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,702
    1,300
    You already have gating to detect certain numbers and reset some counters when they occur. Add more gating to detect the hour 11. That signal goes negative when the clock changes from 11:59 to 12:00, and that edge can clock a toggle flipflop, and the Q and -Q oututs can drive the two LEDs.
    ak
  8. GopherT
    Nov 23, 2012
    6,321
    4,046
    He is using the CD4026 chip (counter to 7-seg driver). There is no accessible BCD. He will need to grab the evidence of a 1 and 2 on the hour display from the 7-segment inputs into glue logic and output that to his flip/flop toggle.
    DickCappels likes this.
  9. Art
    Sep 10, 2007
    797
    61
    If the hour MSD can only be 0 or 1 or have lead zero blanking,
    It looks like you only have to look at one segment of the hour MSD with the flip flop input.
  10. GopherT
    Nov 23, 2012
    6,321
    4,046
    Wouldn't that change the am/PM toggle as the clock clicks from 12:59 to 01:00? Am/PM toggles from 11:59 to 12:00.
    Or am I misunderstanding?
  11. marcf
    Member
    Dec 29, 2014
    149
    20
    If our ancestors had not harbored a pathological fear of the number zero, this programming challenge would not be an issue.
  12. crutschow
    Mar 14, 2008
    13,505
    3,379
    What?? :confused:
  13. marcf
    Member
    Dec 29, 2014
    149
    20
    There is a great book you should read. ZERO "The biography of a dangerous idea" by Charles Seife.
  14. GopherT
    Nov 23, 2012
    6,321
    4,046
    You might want to read beyond the title as well. It is not about leading zeros or the numeral "0" or the second digit of the number 10. It is about the concept of nothingness or beginning and similar mathematical starting points necessary to use math to solve problems and the representation thereof.
  15. marcf
    Member
    Dec 29, 2014
    149
    20
    I agree, but it is not to logical to count up to 12 and then go to 1. It makes much more sense to start at 0 and count to 23.
