12-hour digital alarm clock using ttls
Discussion in 'The Projects Forum' started by bobon721, Oct 9, 2011.
  1. bobon721
    Feb 8, 2011
    I'm currently working on a digital alarm clock project. Programmable ICs are not allowed. I'm planning to use only TTLs because it's all I have and all I can get. My problem is that I don't know how to force the clock to display 12:00 instead of 00:00. I also have no idea how to implement an alarm that can be set and reset, as with the time. Can anyone provide some insight? Thanks. I have my schematic attached.
  2. elec_mech
    Nov 12, 2008
    Hi bobon721,
    This thread may offer some insight:
    Just look up 7400 series equivalent ICs for the CD4000 series ICs if needed.
    What are you using to provide the one second clock signal?
    I can offer help with a schematic and troubleshooting an actual circuit, not so much for a simulation though. In your schematic however, I notice you have a 50MHz clock signal going into the seconds counter (U2). This should be 1Hz if you're trying to simulate a clock.
