Well do we all now the 24V Trick on computer powersupplies? If not you just use the 12V lead as your positive and the -12V lead as ground, and some how you get 24V ( I assume its kerchoffs law)
So My question is, if the 2 sides provide a different amount of current, which side will supply it?
Example
+12=10Amps
-12=1Amps
And my load consumes 4 Amps total. Does it take current from the -12V side first, and then take the rest of the current from the +12V side?
Example
+12=10Amps
-12=1Amps
