12.6 v - 2a Transformer question
Discussion in 'General Electronics Chat' started by SO$hocking, Jan 1, 2012.
  1. SO$hocking
    Jan 1, 2012
    I made a hot wire foam cutter with Radio Shack 12.6v-2a transformer, single pole dimmer switch and a guitar string.
    Q: Do I really need a fuse box?
    Do I need to hook the black middle wire on the transformer up?
    Will I blow this transformer with full dimmer on?
    Thanks. I'm new here and really like this forum already!!:)
    ps. sorry about my scematic pic.
    Transformer specs are wrong on it.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It would be a good idea to put a fuse in the mains side, in case there is a fault in the transformer.
    No, you don't need to connect the center tap.
    As far as the transformer burning up if you turn the dimmer all the way up - hard to say, as we have no clue how much resistance your guitar string has. I think they are generally a type of stainless steel, but resistance would depend upon length, diameter, how much it's corroded, etc.
    If you add a slow-blow fuse on the secondary to, say, 1.5x the transformer's rating, that should take care of it.
  3. SO$hocking
    Jan 1, 2012
    Its a 16 gauge guitar string(i think it refers to thousands of an inch).
    21" long
    I don't have access to a slow burn fuse right now(nor any fuse), but i want to cut foam. BADLY!!!
    Think I can risk it without a fuse for a little while?
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    If the transformer load is a guitar string, you are probably severely overloading the transformer and exceeding the current rating. An easy way to tell is stick a series Amp meter in and see the current.
  5. SO$hocking
    Jan 1, 2012
    I don't have a series Amp meter. I just cut some foam for a couple minuets. The transformer hummed. also stayed cool at the dimmer half way up.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, if the music wire is stainless steel (which I believe it is something similar), and it's 16 mils (same as 0.016", or 16/1000 of an inch), then a 21" length of it should measure roughly 3.79 Ohms. 12.6v / 3.79 Ohms = 3.32 Amperes.
    Do you have a multimeter that can measure AC volts? It would be helpful to know what the transformer measures with no output load on it.
  7. SO$hocking
    Jan 1, 2012
    No meters at all. But this is all good stuff to know!!
