Greetings,
I am fairly new to electronics, and have mostly worked with DC circuits so far. I have an AC fan I want to use to make a carbon filtered ventilation fan for my soldering station. I can do this with a DC circuit and DC fan, but when researching how to do it with an AC fan I came up with more questions than I started with...
The fan I have is a Nidec TA450AC model A30122-10. It is about 5x5x1.5 inches, and rated for 115VAC, 50/60Hz, .26/.21A. I found data on the fan here.
In my research so far it seems there might be three solutions: 1> Use a TRIAC/DIAC circuit, 2> Use a MOSFET circuit or 3> Use a microcontroller/PWM circuit. There seem to be benefits/drawbacks to each method, and I don't know which method to choose, or even if I'm headed in the right direction.. I don't know how to tell if the fan is single-phase, triple-phase, induction... ugh. I am looking for an inexpensive solution I can build myself, that performs well.
Can anyone help me find the right solution for my application? Or at least point me in the right direction?
Thanks much,
doval
Thanks much,
doval
