110vac relay help
Discussion in 'The Projects Forum' started by wfontjr, Feb 23, 2013.
  1. wfontjr
    Dec 21, 2008
    7
    I recently made an automatic chicken door opener. I have a 110vac photodetector wired to 110vac relay. When the relay trips it provides 12vdc to a motor to raise and lower a door. The 12vdc power supply keeps failing, only last a day or two. Do I need to provide diode protection or some other protection from the relay kickback? Is that what is killing my 12vdc power supplies?
  2. crutschow
    Mar 14, 2008
    13,492
    3,372
    Hard to say without seeing the circuit, but relay kickback occurs across the coil of the relay, not the contacts.
    What is the power supply?
  3. wfontjr
    Dec 21, 2008
    7
    thanks,
    the power supply is a wagner 12vdc 5amp from walmart, maybe the motor is pulling more than 5amps?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Do you have a link to the power supply you are using, as well as the motor you are using?
    Simpler, output Current/Amp rating of power supply, and stall current of motor.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Post a complete circuit including motor model.
    Motor windings have an inductance and a resistance. Relay contacts bounce when they open or close. Depending on your motor it may create voltage that affects your power supply.
  6. wfontjr
    Dec 21, 2008
    7
  7. wfontjr
    Dec 21, 2008
    7
    hope the crudeness does not offend anyone for I am only a chemical engineer, the photodector is just homedepot off the shelf
