110v voltage detection
Discussion in 'General Electronics Chat' started by Hessam, Apr 11, 2013.
  1. Hessam
    Apr 11, 2013
    Hey everyone! I'm working on a project that will integrate all my home lighting to a microcontroller. The lights can be controlled manually or digitally from a computer. The only problem I have is that I cannot find a cheap solution for a circuit that will let the microcontroller know if 110v is flowing thru the ac line. Any help would be greatly appreciated.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Volts don't flow through the AC line, current does. Please define what you want to detect and how much.
  3. mcgyvr
    Oct 15, 2009
    4,798
    979
    How about a simple relay.. power the coil with line voltage and use the contacts to pull the micro pin high or low.
  4. tracecom
    Apr 16, 2010
    3,884
    1,396
    Neon lamp connected to mains shining on a phototransistor connected to μC?
    Hessam likes this.
  5. richard.cs
    Member
    Mar 3, 2012
    162
    31
    Can you clarify if you want to detect either 1) that 110V ac is present - I like the neon lamp idea for this, or 2) that current is flowing - probably best done with a current transformer.
  6. Hessam
    Apr 11, 2013
    i would like to detect if there is 110V present. I do like tracecom's idea because i need to make 20 of these
  7. #12
    Nov 30, 2010
    16,705
    7,358
    NE-2 and a 100 k resistor. No problem. This worked in the 1970's and it will still work.
  8. ScottWang
    Aug 23, 2012
    4,936
    777
    That is the good idea, we almost using some other parts but expensive and not easy to solve the problem.
    Thanks.
  9. richard.cs
    Member
    Mar 3, 2012
    162
    31
    If you use a photodiode or a phototransistor you will probably see the neon go out during the mains zero crossings. You either need to allow for this with your microcontroller software, or add a small capacitor to filter it out. If you use an LDR they're so slow you won't see it.
  10. Hessam
    Apr 11, 2013
    Worked perfectly i appreciate the suggestion!
  11. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
