110v transformer?
Discussion in 'General Electronics Chat' started by ray@orbitecuk.com, Nov 24, 2008.
  1. ray@orbitecuk.com
    Nov 24, 2008
    I have a 110V transformer but the output is approx 134Volts thus components controlled by this transformer i.e. solinoid valve is getting extremely hot? can I smooth regulate this transformer output? The transformer is 240V primary with supposedly 110V secondary, can anyone advise?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I think that your transformer's primary windings have begun to develop internal shorts, probably due to overheating.
    That's causing the number of turns on the primary side to effectively become reduced in number, with a resulting increase in the output voltage on the secondary side.
    I suggest that you replace the transformer, preferably one with a higher VA rating.
