110 Led Bulb/Special Switch problem
Discussion in 'The Projects Forum' started by fboisseau, Apr 23, 2009.
  1. fboisseau
    Apr 23, 2009
    I would like to replace an regular incandescent bulb with a LED 110 bulb. The problem is that this circuit is controlled by a X10 switch which seem to allow a small about of power to continue through the circuit. This amount of power is not enough to power an incandescent bulb, but the LED bulb stays lighted. I also have this problem with a circuit controlled by a motion sensitive/timer switch in a bathroom and CFL bulbs.
    Is there a circuit that I could put in place that will basically only allow power to continue to the bulb if it exceeds a minimum level? If there is where can I find information on building it? Can I buy something that will do this?
    Thank you
