11.1V LiPo batt
Discussion in 'General Electronics Chat' started by samuel.whiskers, Apr 2, 2014.
  1. samuel.whiskers
    Mar 17, 2014
    95
    I'm thinking of using an 11.1V LiPo battery in a project, can anyone tell me the expected open circuit voltage of a fully charged one??
    Cheers
    Lee
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,688
    1,297
    What does the battery datasheet say?
    ak
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,514
    Measure it!
    A fully charged O.C. Li_Po cell is 4.2v so you have three in series, = 12.6v.
    Max.
  4. Shagas
    May 13, 2013
    802
    74
    Lipo come in cells. If you are using a 11.1v LiPo that means it is a 3-cell LiPo.
    Each cell has a maximum voltage of 4.2 volts which makes your 11.1v LiPo 12.6 Volts at open circuit.
    Note that you should use a charger that is designed to do LiPo charging .
    Also the discharge voltage of each cell should not drop below 3.2-3.4 volts to be safe so your 11.1 v LiPo will have a minimum voltage of about 10 volts .
  5. Alec_t
    Sep 17, 2013
    5,971
    1,135
