10v to 12v
Discussion in 'The Projects Forum' started by ChevyLT1Camaro94, Jul 12, 2009.
  1. ChevyLT1Camaro94
    Thread Starter Active Member
    Jan 9, 2009
    32
    hey i need to convert the 10v signal my LED strobe box has to a 12v signal but it must be able to switch on and off VERY quickly (its going to be strobing obviously) i figured a transistor, but how would i go about wiring this?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Gee, that's not much information to go on.
    Is this LED strobe box a commercial unit? If so, what's the manufacturer and part number?
    Do you mean that the LED strobe box needs a 10v supply, and you want to operate it in a motor vehicle?
  3. DC_Kid
    Distinguished Member
    Feb 25, 2008
    640
    9
    i'll try to answer given the info supplied.
    you should wire the 2nd wire in series with the 1st so that the voltage needed is there. the strobe box should strobe the way you want it to.
  4. ChevyLT1Camaro94
    Jan 9, 2009
    32
    what?? i have 4 sets of 2 wire leads + and - supplying 10v to an led, i nee to convert that to 12v, sorry for any confusion
  5. DC_Kid
    Feb 25, 2008
    640
    9
    ok. just replace the "10" with a "12" and you'll have 12v.
  6. DC_Kid
    Feb 25, 2008
    640
    9
    ok, what i am saying is
    WE NEED MORE INFORMATION. the info supplied is not enough to answer your questions. post a schematic, etc.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have a schematic for the strobe unit?
    If it's a commercial unit, it's likely that it has built-in voltage regulation, which would be the reason that the output is limited to 10v. This would allow the unit to safely power LEDs over a fairly wide range of voltages coming from your vehicle's electrical system; perhaps as low as 11.5v from a discharged battery up to 14.5v or so when the engine is running and the alternator is charging a depleted battery.
    SOME kind of regulation is necessary for LEDs; preferably current regulation.
  8. ChevyLT1Camaro94
    Jan 9, 2009
    32
    its an led strobe unit from autozone, i want to use it to power led strips instead of the individual high output leds it comes with, but the output i got from my multimeter is 10v instead of 12v, all i need is a relay type thing to make it go from 10 to 12, i thought this was something a transistor could do but im not sure how 2 make that work
  9. ChevyLT1Camaro94
    Jan 9, 2009
    32
    and also, could anyone help me with wiring my own "police style" led strobe controller as well, i know a 555 and a 4017 can be used to do this but i need a schematic drawn up for me if someone could help me out i really need it, i want them to flash like so 111-222-111-222-1212-repeat or if thats more trouble then just 111-222-repeat
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK. So, your strobe unit has a +12v input and ground, and then it also has four sets of output wires that are marked + and - for the four LEDs, correct?
    Now, are the + wires connected to the +12v, or the - wires connected to the ground wire?
  11. ChevyLT1Camaro94
    Jan 9, 2009
    32
    im not quite sure what youre asking, the 4 sets of output wires are + supplying 10v when the flash is on, and then a ground
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What I'm asking is, are the - wires to the LEDs connected to the GROUND input wire?
  13. ChevyLT1Camaro94
    Jan 9, 2009
    32
    i believe the - wires are connected to the ground, the + side is the strobe power side
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you certain about that?
    If you're not, better check.
  15. ChevyLT1Camaro94
    Jan 9, 2009
    32
    im 99% sure ive had the box open before an im 99% sure its ground connected and power is pulsed
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK then, you'll need one of these circuits for each output.
    R1 should be rated 1/4 Watt.
  17. ChevyLT1Camaro94
    Jan 9, 2009
    32
    AWESOME!!! thats PERFECT! if it ends up being the negative side switching could u make one for that too? sorry to bother but i just wanna be safe, like i said im 99% sure but yeah, any chance u could help with the strobe circuit too?
  18. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you want to be safe, then verify that the -wire to the LEDs are connected permanently to the input GROUND wire before you connect anything up.
    If the -wires are being switched, then it's going to be a different ballgame. No sense in me spinning my wheels here if you're not sure what you're dealing with there.
    [eta]
    I omitted a fuse from the previous schematic. Make certain that you have a suitably-sized fuse between the 12v supply and your LED strips, or you may wind up with a burned-up vehicle.
    The attached is a schematic I drew in Feb 2008. It just flashes 1-1-12-2-2 repeat. But if you want real simplicity and flexibility, you'll need to use a microcontroller. The hardest part there is getting over the programming learning curve.
  19. ChevyLT1Camaro94
    Jan 9, 2009
    32
    i just wanted 2 c if there was a difference in the circuit if its the ground side instead of the power side. if i switch the outputs on that secon schematic to go output 123 nothing to 4 and then the second side to outputs 567 and connect 8 to the reset will that do what i want?
  20. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it would be different.
    That would result in 111-222111-222 etc. - but it would look like 1-21-2 etc. There would be no pause between the flashes.
