10V overvoltage protection circuit
Discussion in 'The Projects Forum' started by radetonator, Apr 27, 2012.
  1. radetonator
    Aug 1, 2011
    50
    I want to use SCR to build a 10V overvoltage protection circuit. The circuit should be able to turn on and off SCR. Does any one know how to design the circuit?
  2. lightingman
    Apr 19, 2007
    374
    22
    You mean a crowbar...
    You can use a comparator (LM311) to sense the voltage and trigger the SCR. If you are protecting a DC circuit, you cannot turn off the SCR once it is conducting. You would have to switch the unit off and on again to reset it.
    Dan.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    You need to provide more details, especially what component / circuit you want to protect. A schematic helps too.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    If you are using the SCR in a crowbar mode you MUST have a means of either limiting the current to a value within the specs of the power source/wires/SCR/etc or a properly sized fuse. Simply shorting the output of the power supply is not a great idea. As stated earlier, once the SCR is triggered it will remain in an ON state until power is removed from it.
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
  6. radetonator
    Aug 1, 2011
    50
    to protect a resistance load.
    The problem is how to turn off the SCR. Can SCR be turned off by rail-rail op amp?
  7. radetonator
    Aug 1, 2011
    50
    How to limit the short circuit current without using fuse?
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    Like stated before, more information is needed. Does your power supply have current limit capability? Is the load on the power supply fairly constant or does it vary a lot? What percentage of the power supply capacity are you actually using at the output? The devil is in the details. The more information you provide, the better the answers will be. A drawing would be a great help.
  9. radetonator
    Aug 1, 2011
    50
    The power supply does not have current limit capability.
    Constant resistant load.
    70% of the power supply capacity.
    It would be much easier if SCR can be turned off by rail-rail op amp. Is it possible?
  10. crutschow
    Mar 14, 2008
    13,509
    3,385
    As you have been told by others, an SCR acts as a latch and the only way it can be turned off is by stopping the current flow through it. An op amp, rail-rail or otherwise, can not do that.
    If you want a device that can be shut off then you will need to use a power transistor, either a BJT or a MOSFET.
    You can limit the short circuit current with a resistance in series or a current-limit or current-limit foldback transistor circuit. Goggle will find you many of those.
  11. radetonator
    Aug 1, 2011
    50
    Thanks.
    If a LED has to be turned on and off by SCR, what circuit should be employed?
  12. crutschow
    Mar 14, 2008
    13,509
    3,385
    If the LED is powered by steady-state DC then an SCR circuit will not work. If it's powered from rectified, unfiltered AC then an SCR will work.
    What is the power source for the LED?
    Why this insistence on using SCRs? :confused:
  13. radetonator
    Aug 1, 2011
    50
    haha. I wanna try to use SCR. If using MOSFET, there would be no problem.
    yes, the power source is a 10V DC supply. At initial stage, i will use an adjustable DC power supply.
  14. CDRIVE
    Jul 1, 2008
    2,223
    99
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    There is a simple way to turn off an SCR.
    It is called a fuse. The SCR trips. Fuse blows. SCR resets itself.
    Works every time like a charm.
