Than
I always take advice of AAC people and their suggestions. I have learnt a lot from this forum . I also read article posted here. I can see the difference .
We can not connect SPST switch so let me drive it by NPN BJT or NMOS with controller signal.
One more thing I need to know that how do calculate resistor value and it's power.
Rb= 4.7K ...that I can calculate by looking the datasheet of BJT by considering min ib .
Rb= (Vs-Vbe)/ibmin
200E-How to calculate that 200E and it's power.
Please guide me.
Thank you so much .It is indeed frustrating when you claim a 50% understanding, but you don't take advice. Yes, a BJT can switch the gate, but so can a SPST switch. Try the switch with a resistor from gate to source as I suggested and see if you can get that to work. Then you are free to enhance the switch on the gate anyway you want. BTW, what prompted you to change the gate-source resistor to 200 Ω? Do you understand that connecting the gate to ground will result in a 50-mA current or 0.5W dissipated in that resistor? Be sure to use a resistor that will handle that power.
Going step-by-step is not "reading articles and application notes;" it is a common method to troubleshoot a problem. In the past, you have complained about people at AAC not trying to help you. Please try to learn from that.
John
Rb= (Vs-Vbe)/ibmin
Please guide me.
