10Mhz signal
Discussion in 'General Electronics Chat' started by anurag602, Feb 22, 2009.
  1. anurag602
    Jan 17, 2009
    9
    i need to generate an ac signal of frequency 10Mhz ...also i need current sufficent enough to light up 2-3 60w bulbs, wat shud i do?
    colpitts oscillator seems to be an option..would sum1 care to elaborate about it. :)
  2. anurag602
    Jan 17, 2009
    9
    can sum1 plzz post the specifications of the components of colpitts oscillator which would help me make this circuit...im a newbie..plzz help me out:)
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. anurag602
    Jan 17, 2009
    9
    would the circuits provided in the link be able to sustain that amount of power (i mean the power sufficient dimly light up atleast a 60w bulb). i tried making a very trivial form of colpitts oscillator ,wen i connected it to a 8w bulb, the inductor got roasted to red. :(
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    If you're not opposed to using high voltage, the most straightforward means is with a vacuum tube oscillator, using somethinig like an 811A.
    eric
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    http://www.scifair.org/hvdata/power.html
    This one uses 3 811's but you can get by with just one. :)
