10base2 Ethernet
Discussion in 'General Electronics Chat' started by irastha, Mar 10, 2009.
  1. irastha
    Mar 6, 2009
    5
    Hello all,
    I have been reading articles for 10base2 ethernet connection. Everywhere its written that we should not connect coax between the T connector and the device. The end of T connector must directly be connected to the Device.
    Can anybody please share the reason behind it.
    Thanks a lot
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    Yep. A properly terminated transmission line looks like 75 ohms at all points along the line. If you bridge across the line with an infinite impedance device (which the input impedance of a proper Ethernet card approximates) it won't cause any reflections to occur in the line. However, if you have a length of transmission between an ethernet card and the "bus" transmission line, it can actually look like a dead short 1/4 length back, and at other distances, it can look like a big inductor or capacitor...not good. You might look up some references to the Smith Chart and transmission line theory.
    Eric
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just a few quick notes:
    10base2 used an impedance of 50 Ohms.
    RG58 was typically used.
    Total length of the coax was limited to around 600 feet.
    A 50 Ohm terminator was required at each end of the "daisy chain".
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    Yer right! It was 50 ohms. At least it was SUPPOSED to be. It seems a lot of people threw together systems with 75 ohm cable TV coax because it was so cheap. :) Never seemed to make too much difference. Now, forgetting the TERMINATION resistor DID make a difference!
    Eric
  5. KL7AJ
    Nov 4, 2008
    2,043
    292
    Just saw an article that someone at Iowa State university demonstrated succesfully running 1GB ethernet over 1000 feet of rusty barbed wire. Not recommended for your average installation though. :D
    Eric
