It's starting to sound like you only need to source current, not sink it. If so, you would not need a push-pull output stage. Do you have any limitations on power supplies and grounding. For example, can you have dual power supplies for the OPAMP +/- 15VDC, with 100VDC for the transistor supply and the load connected to ground?It is supposed to be DC coupled, and should be able to make a 100V ramp in about 1ms.
Sorry for the inaccuracy, I didn´t mean a PA distribution amp.
The load should probably not be too big, I guess in the range of 10kohm and more. I don´t have any specifics on the load yet as I am just trying to help my friend, but let´s take this as a starting point.
I don´t need the circuit solved with included exact part numbers, what I need is more of a general topology to achieve this.
by Aaron Carman
by Jake Hertz
by Aaron Carman
