I am working on a project that needs 100VDC @ 1A from standard 110/120 AC wall voltage.
I would like to be able to vary the voltage, not necessarily all the way to 0 but to at least 50VDC. I cannot find such a supply anywhere, aside from very expensive lab supplies, so I have resorted to building one myself.
The output does not have to be super clean as it will be running through DC-DC converters later on.
A full wave bridge rectifier and some filter caps is obvious, but how could I make such a high voltage variable? I have experimented a bit with using power transistors but I cant seem to come up with anything that works reliably. I have some TL783 regulators, which are adjustable, but their max input voltage is 125V, whereas I am getting almost 170VDC out of the rectifier unloaded. At the very least I could step down the AC first with a transformer so I get a low enough voltage out of the rectifier to run into a TL783, but ideally I want to do this without a bulky transformer.
Any thoughts or ideas would be great.
Thanks.
Thanks.
